Discussion topic: identifying potential unauthorised device connected to my network
This message was authored by harry..... This message was authored by: harry.....
I have recently had cause to suspect someone has connected to my network. I have checked off all the mac addresses of connected devices and identified all but one device and need help from sky to identify what this is exactly and if my sky system is therefore compromised leaving me at risk of fraud. I would like to know what this device is, if sky have anything in place to protect customers, and any advice going forward. Also, my homes devices show their mac address with the exception of any iphone in the house. How do i identify what iphones are connected to the network. The list shows 2 iphones when infact there are more and even then the mac address of the iphone does not match the mac address shown in the network list of connected devices. Every time i search sky help website it pushes me away so as not to help. The robot assistance is of no use whatsoever.
Re: identifying potential unauthorised device connected to my network
@harry..... Sky use the standard levels of WiFi security by default the older black hubs use WPA2 PSK and the newer white hub defaults to WPA3-T. While hacking of a WiFi network is possible it is actually extremly rare as it requires significant resouces. The number one cause of third parties being able to access a network is by having the password. Given the device must be within a few yars of your home it is frequently because a member of the family has given it to a neighbour or they have been able to read it off the router label.
If you call Sky the advice they are likely to give is to change your WiFi password to something only you know, see https://www.sky.com/help/articles/find-and-change-your-wireless-password and then log your own devices back in. In practice unless you have disabled the security of your devices a device on your network should not be able to access data on your devices unless you give permission.
harry.....
Hi and thanks for that. Would you happen to know how i identify an iphone as the numbers dont corespondent?
Realistically no ISP will offer help with such issues: in this context it's not 'their' system.
This message was authored by FLC This message was authored by: FLC
Many devices, especially mobiles, now use MAC address randomisation. This means that each time they connect to a network, they display a different, phantom MAC address rather than their actuall address.
https://support.apple.com/en-gb/guide/security/secb9cb3140c/web
You should be able to turn this off on a per network basis, so you should be able to disable it for your home network. That will in turn show the correct MAC address in the Hub, making ID easier.
@harry..... on your iPhone go into the WiFi settings for the Sky WiFi network and you will see an entry for private WiFi address go in there and there are 3 options the default IIRC is a fixed address but the phone can use a rotating address or just the actual mac address for the phone its your choice.
harry.....
yes the mac address listed under wifi address here on the iphone does not correspond with and devices connected. Has anyone any idea which Sky expert might assist at Sky so that i can ask to speak to them. many thanks everyone
As I suggested above, I really don't think you're going to get any help from an ISP.
