Discussion topic: iPad says proxy issues when trying play netflix
This message was authored by: Davidkelly1
Message posted on 25 Mar 2026 11:18 PM
Hi my internet was repaired today now my apple products won't connect to netflix but my sky puck and firetv stick are fine, it says I'm using a VPN or proxy but nothing is on it
Find out more
Message posted on 26 Mar 2026 06:31 AM
Re: iPad says proxy issues when trying play netflix
@Davidkelly1 it ciuld be there is an issue with tge IP,address your connection was allocated when rebooting. Try powering doewn for an hour which should change the public IP address. If thstvdoesnt work look at the security settings on your Apple devices as some like Private Internet browsing can set off such warnings but should not affect the apps but coukd affect Safari.
