Discussion topic: help boost range
Message posted on 18 Dec 2025 03:31 PM
help boost range
An electrician that i worked with showed me this trick/hack. To increase the range of my wifi at home as the far end of my long thin house was not getting any coverage. it appears to work.
Message posted on 18 Dec 2025 03:34 PM
Re: help boost range
@tonydogbite Metal foil will refelect the microwaves the hub uses as carriers for WiFi so it works just like having a reflector behind a light. Ideally you would havevthe hub in the centre of your home .
Message posted on 19 Dec 2025 12:33 PM
unfortinatly it is not practical to have the router in the center of the house. it is where it is.
