Discussion topic: fibre optics
This message was authored by: Taz1372uk
fibre optics
When will you be putting fibre optics on my road ?
I keep getting Virgin fibre asking if i want to join them .
So tempted as i have so many things on my broadband its slowing things down.
I'm going to join Virgin if your not going to put it up my road.
Re: fibre optics
Sky won't be putting any fibre optics oin as they don't install anything, it will be up to Openreach to do that.  Sky won't be able to tell you when this will be may be worth checking here for roll out plans. https://www.openreach.com/content/dam/openreach/openreach-dam-files/documents/Ultrafast_Full_Fibre_b...
This message was authored by: HiHowAreYa
Re: fibre optics
You can also go to the openreach website and check by putting in your postcode and address.
Fibre Checker (openreach.com)
