Discussion topic: fibre is useless
Message posted on 09 Mar 2025 01:19 AM
fibre is useless
according to sky test my broadband is 107 mb but I have done a speed test and my downliad speed is 5.15mb and upload speed is 2.94. Laptop disconnects from bradband every few seconds and the tv keeps freezing and saying I have np satellite signal
Message posted on 09 Mar 2025 04:42 AM
Re: fibre is useless
A no satellite signal message is due to a misalignment of your Sky dish and not internet related. If you have Sky Q and you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
Message posted on 09 Mar 2025 05:53 AM
@mase1 if you run a speedtest over wifi you often end up measuring the wifi speed in your home between the hub and your device. Poor wifi is very common as it is affected bybthe lsyout and type of construction in your home. To test the connection gusrantee use a devicecconnected by gigabit Ethernet
