Discussion topic: fed up with changing dates for an engineer
This message was authored by: dessie1
Have been waiting for fibre since mid May, supposed to have been coming on the 2nd June, then that changed to 25th June then to the 2nd July and now to the 30th July, I sugest that you forget trying to connect me to fibre and I will get it done with another company when my sky contract expires !!!
Re: fed up with changing dates for an engineer
@dessie1
This is predominantly a customer led discussion forum where Sky customers are available to help other customers. You aren’t contacting Sky Customer Services by posting here.
Have Sky indicated what's causing the delays?
Typically any other Openreach ISP will face similar delays because the required infrastructure is the same no matter who the supplier is.
