Discussion topic: ethernet
This message was authored by: Emily50
ethernet
I don't understand how this works but I have 2 ethernet plugs one goes into the back of my wifi and the other is in my room plugged into my pc usually I'm assuming they connect without having to use a 50m cable but on the actual ethernet plug itself all the lights are green ( ethernet and power) but one which is the data and that one isn't showing up as green and I don't know how to fix it. neither of the data lights is showing up (the one plugged into my wifi and the one plugged into my PC) Sky is the wifi provider and I'm using BT ethernet plugs if that's the issue why? I've had them for over 4years and had no issues with them before, I usually wouldn't care but the wifi is so slow and unpredictable and stops working at random moments when i use my ethernet the wifi is great and have no issues which are why i need this fixed I also use the ethernet because otherwise when trying to play games like (valorant, R6 or The finals) my ping skyrockets into the 100s but when using ethernet it stays down between 8-13
Re: ethernet
@Emily50
'BT ethernet plugs' are standard PLC adapters.  such devices tend to be sensitive to local current, and so it's possible either end (or both) has just fried and died, perhaps related to recent storms.
Somewhere on the BT website there's probably a support page indicating how to carry out a hardware reset: if that (and the usual unplug/replug/re-seat connections doesn't work) then the only real option is to purchase a replacement pair.
Avatar for Emily50
Re: ethernet
@TimmyBGood
It was working last night till around 2:45 am when the internet and voice on the actual wifi box was orange but the internet was still working on devices like my iPad but not my Xbox and i was able to use the ethernet at that time on my pc as well so it would only work for some devices but not others either and i woke up this morning to it not working at all for anything but the wifi and voice are both green and working on all devices (slow but still working)
