Discussion topic: engineer appointment not honoured
This message was authored by: Esianos
Today I had scheduled an appointment for establishing my sky connection, in my new home, after I moved recently.
The engineer never came.
Moreover, the chat feature is permanently offline and the phone call feature is also always too busy and the automated message says to go online...
How can I speak to someone and get things arranged?
Re: engineer appointment not honoured
@Esianos
Contact Sky in the morning when the lines reopen as by that time they'll have hopefully received an update from Openreach / City Fibre.
The current methods for contacting Sky are below and depending on your reason for making contact some methods will be more appropriate than others……
🟩 📞 Customer Services by dialling 150 (free) from either a Sky mobile or a Sky Talk landline. The forum doesn’t allow the display of other numbers. Other official numbers to Sky from the UK are 03 numbers which are normally inclusive from non Sky phones.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
🟩 online help via this link
https://www.sky.com/help
🟩 Sky Assistant 💬 should also be available via
🟩 Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
🟨Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
