Discussion topic: devices pause
Message posted on 05 Oct 2025 11:49 PM
devices pause
hello, everybody my sky app it's pausing my device , my desktop only the desktop, i go into the app, i wake up and after 5 mins they pause again, why
Message posted on 06 Oct 2025 07:33 AM
Re: devices pause
@Cosmin11 you post is not terribly clear. Are you referring to the My Sky app itself? Given there isnt a native windows version of thst app so it can only be run using an Android emulator any misbehaviour could be down to that. Alternatively do you have issues with another of Sky's apps like Sky Go? If you want support with that post in the dedicated Sky Go forum https://helpforum.sky.com/t5/Sky-Go/bd-p/skygo but include a clearer description of tgecfault and includecwhat version of windows you are running.
However from your description it is unlikely to becanything to do with your broadband connection.
