Discussion topic: connection security
This message was authored by: grumbletum
connection security
i ran a full diagnostics on my desktop p.c  and the one report i got back said,   ( your router has no secure connection with HTTPS)
Re: connection security
@grumbletum
Routers typically don't use HTTPS for their own administrator web pages (because they don't have a real SSL certificate onboard)
This isn't generally considered to be a security issue because these pages are only accessible from the local network, and if there's a hostile actor inside your LAN then you've got bigger things to worry about.
