8
This discussion topic has been answered Discussion topic: connecting a computer via 5GHz
This message was authored by: lisat0612
how can I connect a computer to the wifi network using 5GHz rather than 2.4GHz? I could connect my computer to 5GHz on my old provider router but there doesnt seem to be the option to choose on my sky router? I've logged into the router settings but there doesn't seem to be the option to choose which network to use without disabling 2.4GHz but then computer won't connect at all.
Re: connecting a computer via 5GHz
@lisat0612
The Max Hub apparently doesn't permit unsyncronising the bands and having a different SSID for each of them.
Depending on the client device, you may be able to disable 2.4Ghz at that end.
@lisat0612
As posted by @jamesn123
Note that this process does not apply to the new (white) Max Hub
So to split the two channels you need to go to your router config page which can be found by typing 192.168.0.1 into your web browser.
To access the page, you'll need;
username: admin
password: sky OR your WiFi password
- Select wireless from the navigation bar and scroll down a little and untick the 'Synchronise 2.4GHz and 5GHz settings'
- Scroll to the bottom of the page and hit apply.
- Once the page reloads you need to go to the 5GHz wireless settings page on the sub navigation bar below where you click wireless before
- In the 5GHz section you want to go to the box called 'Name (SSID)' and add something like 5g to the end of the current name
- Scroll down and hit apply
- Then on any wireless device you should now see two networks. One network will be the same name as usual and will be 2.4GHz band and the other will be the usual name with 5G on the end (Or whatever you typed). Connect any 5GHz capable device to the 5GHz network and see if it works correctly. The WiFi password should be the same if you havent changed it.
Avatar for lisat0612
thank you for responding. I have the new white hub so im guessing this wont work?
@lisat0612
@lisat0612
https://wccftech.com/how-to/how-to-change-between-2-4ghz-and-5ghz-wifi-bands-on-windows-10/
thank you, we tried disabling the 2.4GHz but it won't connect to the internet at all then. Will have a look at the other solution you posted
This message was authored by: Laurad1978
Hi was just wondering if you found a way? I play xbox s but I'm lagging so much I can't play rl am having to use my ee mobile data
I can't remember for sure but I think we got a new wifi dongle for the PC that was able to change between the bands  and also a better TP-Link router that is also connected to the sky router, so one of them is acting like a modem, I think. The extra router has improved the connection for everything though
This message was authored by: Debaline
This is a common issue.
Check this guide Fix 5GHz WiFi Not Showing Up In Windows 10/11 [Resolved]
Log into your router  - select Connection - Staus and then click on edit  on the 5GHz Network as below
Set to manual  - select ch36 - save - then set to automatic and save again.
It should now be on ch36 and automatic as below.
You may have to change the settings on your PC/Laptop as mentioned in the guide.
Hope this helps.
