Discussion topic: broadlink pro
Message posted on 06 Nov 2024 01:22 PM
broadlink pro
I'm trying to connect a Broadlink pro to the Sky max router with no success. I have tried everything that Broadlink has suggested but nothing will allow me to connect it. I previously had it connected with a Virgin Media router with no problems. Is this device compatible with the router?
Message posted on 06 Nov 2024 01:27 PM
Re: broadlink pro
With a white Max Hub you may need to reduce the wireless security level from WPA3 to WPA2-PSK using the Hub settings in the My Sky app.
You can use the same settings to temporarily disable the 5Ghz WiFi band: remember to re-enable it afterwards if you do this.
Message posted on 06 Nov 2024 02:43 PM
Re: broadlink pro
Thanks. That worked perfectly.
