Discussion topic: broadband gone down
This message was authored by: Jo19661
broadband gone down
our internet isnt working. The app detects no issues though. We have rebooted but no joy
Re: broadband gone down
@Jo19661
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
