Discussion topic: blocking ps5 on my router
Message posted on 13 Feb 2024 08:56 PM
does anyone know the best way to block a ps5 using firewall rules, I have tried apply static ip address to the mac address on the ps5, but for some reason they are able to keep getting new IP address and getting around the rules.
Message posted on 14 Feb 2024 07:05 AM
Re: blocking ps5 on my router
@Hannibah being able to simply spoof a mac address is why mac filtering is effectively useless these days. No parental control app is 100% effective against a determined tech savy kid - or even one with a tech savy mate.
I suggest you check out purpose designed parental control solutionsyou can buy or the one in Sky's Wifi Max hub which may help control the wifi access BUT remember the only 100% effective system is unplugging the router.
Message posted on 14 Feb 2024 09:01 AM
I don't think wifi max is available yet to sky q customers 😞 thanks for your reply x
Message posted on 14 Feb 2024 11:34 AM
@Hannibah one slightly odd ball idea is to buy acheap wifi access point which you use to conect the PS5 and turn that off when you decide to limit connection but change the wifi password on the hub to something only you know.
Message posted on 14 Feb 2024 11:51 AM
Great 😊 thx
