Discussion topic: **bleep** broadband and WiFi.
Message posted on 29 Nov 2025 03:46 PM
Message posted on 29 Nov 2025 03:51 PM
Re: **bleep** broadband and WiFi.
@JamesGuest
We are customers and this is a customer ➡️ customer discussion forum where we try to help other Sky customers. I’m afraid you aren’t communicating with Sky by posting on here.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
