1
This discussion topic has been answered Discussion topic: bad wifi
This message was authored by: tracyhansford
bad wifi
wifi keeps dropping out
Re: bad wifi
@tracyhansford
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
Re: bad wifi
@tracyhansford
