05 Jul 2023 11:56 PM
hi guys and girls
im wanting to get a replacment ai mesh node as the ax mini ive just sent back as noting would connect to id anyone got recomendations even another asus ai mesh router ? thanks
ps RT-AX58U working fine on full fibre FTTP
06 Jul 2023 10:06 AM
I guess I could use the original sky router as router only and then use the Asus as the main Wi-Fi feed ? Any thoughts
cheers
06 Jul 2023 11:18 AM
Posted by a Superuser, not a Sky employee. Find out moreI am confused as to what you are asking, if your Asus router is working fine directly connected to the FTTP ONT why would you put the Sky router back?
06 Jul 2023 11:23 AM
Sorry if it's confusing. The original question was for a diff mesh node. And the 2nd response was after reading some have used their sky router on router only mode so thought someone might have done that.
Reasoning I was then thinking I could put the Asus more in the middle of the house I maybe wrong.
sorry for confusing things.
06 Jul 2023 11:35 AM
Posted by a Superuser, not a Sky employee. Find out moreYou could do that with the Sky hub but then you lose functionality with the Asus unit not being in router mode so I wouldnt change that.
As for the mesh node, any of the Asus units should do, it all depends on how much coverage you want and the WiFi standard you want (WiFi 5, 6 or 6e)
06 Jul 2023 11:41 AM
When the ax mini worked it was fine. I was shocked that the tele support didn't want to know. 😳
06 Jul 2023 03:21 PM
After quite a bit of research for my own interest, it appears to be any of the extendable AI mesh routers or extenders would be fine.
You want to match the AX speed to avoid any slower connections and make sure it has enough LAN sockets if you need them. Another RT-AX58u would work nicely in mesh mode but it might be overkill for your needs.
I bought a TUF-ax6000 with the intention of getting another aiMesh device if needed but the improvement over a Sky Hub negates the need.
