Discussion topic: Zero connectivity
Message posted on 30 Aug 2025 01:19 PM
Zero connectivity
Zero broadband connection, all fine for months and now nothing. Possibly the hub but I don't know. Incredibly annoying.
Message posted on 30 Aug 2025 01:28 PM
Re: Zero connectivity
@Andy408
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
Message posted on 30 Aug 2025 01:29 PM
@Andy408 This may help you see what you have.
