Discussion topic: Xbox conection
This message was authored by: Tkally
Message posted on 24 Jul 2026 04:51 PM
Xbox conection
My wired connection keeps dropping below 80 mbps and as low as 2mbps and it should be at 500
This message was authored by: Shaun-87
Message posted on 24 Jul 2026 05:10 PM
Re: Xbox conection
My son had this issue. I then purchased a 1gig network switch which seemed to sort his issue out. I would say to get one and try it. If it doesn't work, then send it back. What sky router do you have?
