Discussion topic: Xbox and ps5 are not connecting
This message was authored by Steveefc This message was authored by: Steveefc
Just gone to sky and got most things to connect apart from Xbox and ps5 which say the signal is weak
wpa 2 doesn't change anything unfortunately
Re: Xbox and ps5 are not connecting
@Steveefc to connect games consooes you need a strong stable network connection if the rooms your unitsxare in is not getting sufficent signal then even if you can getvthem to connectvthe gaming experiencecwould be dire. While you could pay Sky for their WiFi Max add-on which can provide up to 3 extenders it msybe better to considercan alternative.
Ideally you woy]uldcrun an ethernet cable for the hub to each console but thst is often impractical instead you may wantvto consider buying a powerline networking kit which uses your main's wiring to carry the data. These are normally far better for gaming than a boostercsystem.
Steveefc
HI Just wanted to connect for updates as I don't actually play online thought it was fine just to do that
