Discussion topic: Work dropped out and won’t come back
Message posted on 21 Jul 2026 10:11 AM
Hi there
my wifi has dropped out and resetting it still doesn't work, the service checker says it's find but I still have no internet
Message posted on 21 Jul 2026 10:23 AM
Re: Work dropped out and won’t come back
@Jameswallis
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
