Discussion topic: Work VPN not Working
This message was authored by: Steve305
Hello, I have recently started using the Sky Max Hub. My work VPN has not worked since moving to Sky broadband. I have been told by my IT department to get Map-T disabled and make sure the Map-T ratio is 1:1 rather than 8:1. In theory, they say this should then solve my vpn issue. Please could I have some help in getting this problem solved? Thanks
Re: Work VPN not Working
@Steve305
Glad to see that at least some businesses are getting that message.  I've escalated your post.
This message was authored by: GlitchHaven
Im having the same issue, was fine last week then when i worked from home wednesday it wouldnt work, i have the sky max hub
This message was authored by: Addie15
Hi there! Thank you for escalating this. We have sent an invite to @Steve305.
