Discussion topic: Wiring damaged, wifi not connecting
Message posted on 07 Sep 2024 04:07 PM
Wiring is damaged, WiFi not connecting. Need someone to come out and install new wiring from outside to broadband hub
Message posted on 07 Sep 2024 04:29 PM
Re: Wiring damaged, wifi not connecting
@RafeenYou will have to call Sky to report that fault, no-one her can do that as we are all just fellow customers.
Message posted on 08 Sep 2024 09:08 AM
@Rafeen Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
