Discussion topic: Wireless network key
This message was authored by: LaTrine1
Message posted on 09 Oct 2025 01:19 PM
Need wireless network key for my PC. I am entering the mac. Code on back of router but keeps saying incorrect.
Find out more
Message posted on 09 Oct 2025 01:30 PM
Re: Wireless network key
It isn't the mac address you should be entering but the network key that should be printed on the hub, it is also on the card that came with it.
This message was authored by: aac74
Message posted on 09 Oct 2025 01:34 PM
Does your wireless key have and zero or O or i or L characters?
They are easy to confuse between uppercase and lowercase.
Have you tried entering it in your phone?
