Discussion topic: Wired/ethernet connection
Message posted on 16 Oct 2024 06:48 PM
http://192.168.0.1/sky_system.html My PlayStation 5 has been plugged into my Ethernet cable for the last year no issues. Last couple of days I've noticed, lag and other issues. So I switched to WiFi, but it's really laggy. I tried to go back to wired, now the ps5 wont connect to the network. I only get laggy play on WiFi and no connection on wired /lan. I have tried new Ethernet cable, tried rebooting the router, everything no joy. Any Ideas, I did this stats report on the router, but I don't know what it tells me
Message posted on 17 Oct 2024 09:50 AM
Re: Wired/ethernet connection
Is it direct ethernet from the hub to the PS5 or something inbetween such as powerline?
Message posted on 17 Oct 2024 10:47 AM
Yes there is a power line. Between it.
Message posted on 17 Oct 2024 10:54 AM
Then its probably your powerline adapters that need re-pairing or have died.
Have you tried running a direct cable without the powerline adapters as a test?
