24 Apr 2023 02:57 PM
I've been connected to Sky Broadband for four days, and have continual connection drop outs. I'm not using WiFi for every device - my Home PC is a Cat5 wired connection and drops out all of the time.
The wifi devices also drop out at the same time.
Phone is crackly but works.
Anyone any ideas?
Cheers
Stuart
24 Apr 2023 03:03 PM
Can you post your hub stats as shown below
24 Apr 2023 04:25 PM
sure - thanks for the help:
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 16641797 273723 0 26484 28712 00:03:22 LAN Up 133495 11592179 0 460035 18332 01:43:36 WLAN (2.4 GHz) Up 27166 4672 0 7735 736 01:41:57 WLAN (5 GHz) Up 98196 90424 0 27925 26356 01:41:55
25 Apr 2023 11:45 AM
Posted by a Superuser, not a Sky employee. Find out moreIf your phone is crackling then this suggests a line problem. I would call Sky to report it as a phone fault rather than broadband as they will send a phone engineer who can diagnose the crackling which will in turn likely fix the broadband
