5
This discussion topic has been answered Discussion topic: Will This Router Work With SKY FTTP
This message was authored by: VirtualPostman
https://www.amazon.co.uk/gp/product/B083QSG6QK/ref=ewc_pr_img_1?smid=A3P5ROKL5A1OLE&psc=1
Does anyone know or have experience of this router for use with SKY FTTP.
Ive just moved from BT to SKY and horrisifed that my Netgear RAX10 doesnt work with SKY.
Im currently using the absiolutely crappy sky router/hub and there seems to be issues with it. Very slow loading web pages and apps that take ages to get the data or timeout though speeds are fast.
Im either looking at the above or possibly getting a unifi express, not sure if the unifi express supports SKY FTTP either.
Thanks for any help with this
This message was authored by: cookiemonsteruk Answer
Re: Will This Router Work With SKY FTTP
@VirtualPostman
The asus xt8 zenwifi will definitely work directly attached to the openreach ont
Avatar for VirtualPostman
Just to add i only have SKY FTTP and am using the SKY PUCK for sky TV
@VirtualPostman
I was just reading another post that you had answered with comaptible routers and that was one of them just as you replied.
Cheers
@VirtualPostman
The xt8 should already come with skys authentication protocol
On wan settings screen select auto ip and look for client identifier (option 61) and enter
anything@skydsl|anything
And you should be good to go
This message was authored by: peter-marlow+1966
I  fftp with  sky 500mps  and I have  the sky wifi max hub, 55inch sky glass tv and 1 puck all works fine
P c marlow
