Discussion topic: Wifo not working
Message posted on 23 Jun 2026 11:12 PM
Wifo not working
broadband speed is very less
Message posted on 24 Jun 2026 04:23 AM
Re: Wifo not working
Not working or slow?
If the Wi-Fi has become slow see any troubleshooting in this link https://www.sky.com/help/articles/broadband-diagnostic-start
If not working use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
