Discussion topic: Wifi
This message was authored by: Beddy1982
Wifi
I have upgraded my wifi 2 times now and still not wifi in any part of the house only the room the box is in . i have paid 2 payments for wifi i cant use . This is not a service i should be paying for .
Re: Wifi
@Beddy1982 if you live in a home with very thick solid internal walls poor WiFi is somewhat inevitable however if your home is modern with foil faced insulation in the walls you can have the same issue. However check that your hub is in the best position which is out in the open on a surface not on the floor.
Beyond that you msy need either to pay to run Ethernet cables to othercarea in your homecand use those to connect the extenders you have presumably bought.  An alternstive is to invest in some Powerline networking adapters thst use the mains wiring to carry thecdata.
