Discussion topic: Wifi
Message posted on 17 Jun 2026 04:14 PM
Wifi
Cannot connect to WiFi was connected then went off and cannot reconnect
Message posted on 17 Jun 2026 04:44 PM
Re: Wifi
What lights sre lit (or not) on your hub, if any are out of flashing then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
