Discussion topic: Wifi
Message posted on 07 May 2026 02:05 PM
Wifi
WiFi has gone off no connection
Message posted on 07 May 2026 02:15 PM
Re: Wifi
@Sarahsal
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
