Discussion topic: Wifi
Message posted on 18 Apr 2026 05:29 PM
Wifi
Message posted on 18 Apr 2026 05:42 PM
Re: Wifi
Wi-Fi or broadband? Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
