Discussion topic: Wifi
Message posted on 30 Mar 2026 08:47 PM
Wifi
My wifi bot not working
Message posted on 30 Mar 2026 09:53 PM
Re: Wifi
If you have Sky Fibre and your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
