Discussion topic: Wifi
This message was authored by: Lynsie
Wifi
My Wi-Fi isn't working properly
Avatar for Lynsie
Re: Wifi
Wi-Fi not working
Re: Wifi
@Lynsie Help is not going to anything good either, switch it all off to start with as a reset!
Avatar for Lynsie
Re: Wifi
Already have done not helped
Re: Wifi
@Lynsie You either need to give some detail or call sky from your landline by dialling 150 8am - 8pm and speaking to Customer Service!
You may wish to do the following in the meantime!
Try running the line test here to see if any faults are found:
