Discussion topic: Wifi
This message was authored by: AlexDeeming
Wifi
WiFi is performing badly. Teams calls are buffering heavily. Have tried rebooting the router, repositioning and still no change.
Re: Wifi
@AlexDeeming Teams does nor require a fast connection but is easily disrupted by an unstable WiFi connection which is why for any serious business use Ethernetvis a far better connection. Assuming your hub is out in the open on a surface well ff the floor and miving to working closer to it are not options then you will need more WiFi equipment
Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
