Discussion topic: Wifi
Message posted on 01 Feb 2026 02:12 PM
Wifi
Everything says it is working correctly but the WiFi has been intermittent for the last two weeks. It is preventing us doing work at home and extremely frustrating.
Message posted on 01 Feb 2026 02:16 PM
Re: Wifi
@Andrew822 Wifi or Broadband they are TWO seperate issues to be looked at!
Message posted on 01 Feb 2026 02:49 PM
Re: Wifi
The internet isn't working. The connection shows as strong but devices such as phones and laptops drop out. The TV seems fine.
Message posted on 01 Feb 2026 02:58 PM
Re: Wifi
@Andrew822
As stated Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your ISP (Sky).
With any broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Message posted on 01 Feb 2026 03:13 PM
Re: Wifi
@Andrew822 If the broadband goes, then EVERYTHING connected goes off not partial ie the TV works fine, unless the TV is connected on the Ethernet and that is working, so the Broadband is up....
Yes you can lose the wireless wifi so everything that is wireless connected goes off, then as you have stated WiFi is the issue! The statement the connection shows as strong, what is that and what / were are you seeing it, ie wireless bars are up, there is an exclamation mark shown, so Wireless fine but NO internet connection data is NOT flowing on the WiFi side!
