Discussion topic: Wifi
Message posted on 31 Jan 2026 07:43 PM
Wifi
My WiFi randomly stopped working but on the online checker says everything is good?
I have noticed that I've got an orange indicator on the voice part of the WiFi hub but rest are green
can't anyone help.
tried the usual, power down reset on back of box
Message posted on 31 Jan 2026 07:47 PM
Re: Wifi
@Wozza9
With any broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
