Discussion topic: Wifi
Message posted on 29 Jan 2026 05:01 PM
Wifi
My wifi is not worki
Message posted on 29 Jan 2026 05:03 PM
Re: Wifi
@RobertMunemo
With any broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
