Discussion topic: Wifi
This message was authored by: Mo121
Wifi
WiFi isn't working, but says everything's fine, this is happening a lot recently with sky
Re: Wifi
@Mo121 Couple off links below for you to go check what your line is like as your post says nothing of any help!
Try running the line test here to see if any faults are found:
or later if you are still not connected....
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby if enough time has passed for a fault condition to be displayed by the software test! This should determine if there's an identified fault affecting multiple households.
Avatar for Mo121
Re: Wifi
Power is green, internet is orange, wifi is green, voice is orange, why is this not working, I've tried trouble shooting it, nothing is working and this is very annoying, I cannot even work. This problem is happening too much, need this sorted now!
Avatar for Mo121
Re: Wifi
It says there is a fault. But then saying it's all good, but nothing works
Re: Wifi
@Mo121
With any broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
▪️I AM NOT A SKY EMPLOYEE ▪️
Avatar for Mo121
Re: Wifi
I am following the steps, nothing has been fixed
Re: Wifi
@Mo121
Have you notified Sky? If so, how long ago?
Re: Wifi
@Mo121 You need to do the call to sky dialling the 150 on your landline if working, a sky mobile if you have one that is the same number also! Online does not fix it all!
