Discussion topic: Wifi
This message was authored by: Nataliegower
Wifi
My WiFi is not working, no lights on the hub at all
Re: Wifi
@Nataliegower
See further down for guidance on the lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
▪️I AM NOT A SKY EMPLOYEE ▪️
