Discussion topic: Wifi
This message was authored by: Fudge0312
Wifi
The signal is terrible.  You cannot sit 10m away from the hib and not looses signal
Re: Wifi
@Fudge0312 You may just have to boost the wireless wifi signal then, 30' and a possibly wifi6 signal you may just be on the edge depending on your sky Hub in use!
