Discussion topic: Wifi
Message posted on 07 Jan 2026 01:47 PM
Wifi
My wifi is down once again, this has been the 3/4th time in last month.
ive doene the checks and everydays its fine and connected, its not
Message posted on 07 Jan 2026 01:48 PM
Re: Wifi
@Chloe924
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
Message posted on 07 Jan 2026 01:52 PM
Re: Wifi
Also having the same problem. Broadband connection has been going on and off all day
Message posted on 07 Jan 2026 01:55 PM
Re: Wifi
Obviously the same advice applies.
