Discussion topic: Wifi
This message was authored by: Janine61
Wifi
My WiFi keeps going in and out
Re: Wifi
@Janine61
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
