Discussion topic: Wifi
Message posted on 09 Dec 2025 12:36 AM
Wifi
Whats happening with the WiFi on off on off might make my payments like that
Message posted on 09 Dec 2025 04:23 AM
Re: Wifi
@Daveburtay
You aren’t contacting Sky here. This is a customer ▶️ customer discussion forum where we try to help other customers.
As you've posted at 0036, any broadband issues between midnight and 0700 could be essential overnight maintenance taking place which is carried out then to minimise disruption. There’s no pre-warning of this. See this pinned post at the top of the Broadband board from Sky which could be relevant any night this happens…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
Hopefully it’s back up and running before 7am.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
