Discussion topic: Wifi
This message was authored by: Tonyhenry
Wifi
I dont have any wifi and my box has red lights flashing on it
Re: Wifi
@Tonyhenry
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back up and running before 7am.
If it hasn't returned, even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
▪️I AM NOT A SKY EMPLOYEE ▪️
