Discussion topic: Wifi
This message was authored by: Ajgardz
Wifi
All connected but not working have reset hub and still not working
Re: Wifi
@Ajgardz
Use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it)
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
