Discussion topic: Wifi
This message was authored by: bernardmc
Wifi
I constantly lose WiFi while I'm at home and when I do a check on it says everything OK.
Re: Wifi
@bernardmc
Use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it)
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
