Discussion topic: Wifi
Message posted on 25 Oct 2025 07:30 AM
Wifi
Message posted on 25 Oct 2025 07:58 AM
Re: Wifi
As we don't know which hub you have the below link explains the lights on the various hubs https://www.sky.com/help/articles/hub-lights-explained-start
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
