Discussion topic: Wifi
This message was authored by: tricia+4007
Message posted on 08 Oct 2025 06:28 PM
Wifi
Computer and tablets having connection problems the sky glass is taking an age to load programs ,our hive is also having connections problems
Message posted on 08 Oct 2025 07:15 PM
Re: Wifi
@tricia+4007 If you have a sky Max hub, then check and lower it to WPA2-PSK mode, link below helps and explains!
Sky Max change settings link.
https://www.sky.com/help/articles/change-wifi-max-hub-settings-a
