Discussion topic: Wifi
Message posted on 04 Oct 2025 05:34 PM
Wifi
Wifi dropping out
Message posted on 04 Oct 2025 06:26 PM
Re: Wifi
@TraceyRosten
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
